Growing up in the arcade generation, and with the creation of MAME, I desired very much to have the perfect arcade controller designed exactly the way I wanted it. When I first started my search I noticed that Tim Eckel of the ArcadeAtHome site had designed a great controller. And Tim was willing to build one for me (and only one) - a prototype so that he would also get a chance to document all the building steps for his site. But alas he got too busy, so instead he pointed me to Arcade Solutions.
At Arcade Solutions
I spoke with Andy Desak, and explained my situation. Not only did
I want to completely specify the entire layout, but I also wanted to add
both a trackball and a spinner, a combination that at the time and to my
knowledge had not been done before (and probably still to this day is only
available for sale at Arcade Solutions).
![]() (Click for a larger view) |
Andy didn't hesitate from venturing into new territory. He scouted out additional high quality parts for the spinner and found a unique and clever way to hook the spinner and and trackball together so that they both worked off the same (serial) connection to the computer. All I have to do is throw an easy switch in the back and I can select on the fly whether to use the spinner or the trackball. Since no games that I know of require both, this solution is very efficient. Additionally Andy made sure that his custom designed spinner would handle and last like a real arcade unit. Its made from very solid parts, and from one spin it keeps on spinning many times.
The unit performs very well. Its programmable and I can also even use both my normal mouse and keyboard at the same time with the unit (without any switchboxes).
I also have to say that after looking inside the unit by opening the access panel on the bottom of the unit, I am just as impressed from the workmanship on the inside as the great appearance of the unit on the outside - its build like a truck and wired very neatly. There's also an attractive handle on the side of the unit which allows you to carry the unit with one hand.
I found Andy to be very good to work with. He was patient and was willing to talk in length to whatever degree that was necessary to understand all the details I gave him. He even sent me some verification pics of my specified layout during the design phase to help insure that everything was accurate.
Overall I am extremely
pleased. This unit should last a lifetime, and its just what I wanted.
